shellac on dial cord to secure dial indicator/pointer?
This question pertains to a Philco model 40-180 chassis.
I read somewhere that it is advisable to use shellac to secure the dial pointer/indicator assembly to the dial cord.
Where is a good source to buy this shellac product?
Would super-glue do the job just as well?
Thank you in advance,
Phil D
Phil D Wrote:This question pertains to a Philco model 40-180 chassis.
Phil D
A dab of nail polish does the job. Should you need to reposition the pointer later, a drop of acetone will soften the nail polish. I buy the cheap red one at the dollar store. It is real lacquer believe it or not. The clear nail polish does a great job of mending light scratches on radios (along with a felt tip pen to hide the scratch). I would not advise using super glue.
Syl
Syl,
I appreciate the quick reply and answer to my question.
Fingernail polish is sure easier to find than shellac. For a onetime fix, this is the way I will go.
Thanks again for the help that I have received on this forum.
Phil D
I just use the first sticky thing I can reach on the bench Icon_smile Shellac would be at the bottom of the list of things to choose from.
Good old-timey Duco cement is handy to have within reach. So are those .000004 ounce tubes of crazy glue.
While were sharing ideas on this subject, I have always used a small-dab of clear GE 100% silicone household glue applied with the tip of a toothpick. Can be removed easily also for re-positioning dial pointer if needed even after full dry if not too much is used. Silicone wont break down over time with moisture, heat/cold , etc. Flexible also.
Thanks Arran; I don't even know what a double conversion is, but i do have a good friend In Nova Scotia that would k...Dan Walker — 07:01 PM
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 4876 online users. [Complete List]
» 4 Member(s) | 4872 Guest(s)
AvatarAvatarAvatarAvatar
