40-180. Pushbuttons work, manual tuning doesn't !!!SOLVED!!
SOLVED! The wire from pin 1 on the oscillator coil, through 29A to the pushbutton was in the proper place. However, the wire that went from the pushbutton to pin 5 of the 6J8 wasn't. Therefore, 29A and the coil were not conected to the tube.
Aye! Glad you got it.
There are currently 6173 online users. [Complete List]
» 3 Member(s) | 6170 Guest(s)
