Will Philco 630 Speaker Fit Philco 620 Cabinet?
I am restoring a Philco 620 chassis only (I don't have the cabinet.) and someone has cut the original field coil from the old speaker frame and substituted a really "funky" PA type speaker. I'd ike to restore it to its original condition. I have spotted a Philco 630 speaker and wonder if it will fit the Philco 620 cabinet. Any help will be appreciated.
Thanks and may God bless!
Roger Bentley
rogerben@bellsouth.net
Here is the speaker bulletin that should list both models electrical spec's.
No physical dimensions are given though.
http://www.philcoradio.com/phorum/showth...hp?tid=215
Bill
It's not what you don't know that hurts you it's what you know that's not so.
Hi Roger
Short answer: Yes.
Assuming you are referring to tombstones here as opposed to consoles (floor models)...
The 620B originally used an S-14 speaker; the 630B, a K-32. Both have the same electrical specifications; the K-32 has a larger voice coil and larger field coil, which offers improved fidelity over the S-14. Both are 8 inch units, and the bolt holes are the same.
Thanks to both of you! Thanks Ron. Your size info is what I needed! I really appreciate it.
Roger
There are currently 9847 online users. [Complete List]
» 1 Member(s) | 9846 Guest(s)
