Threads: 113
City: The Villages
Since I've run across a problem like this. I have a 49-905 that I just finished replacing all the electrolytic and paper capacitors. All tubes and resistors check ok. My problem is a hum. It gets louder with the volume control but never over powers a station. I checked all the wires and they appear to be dressed as original. Even though the tubes tested good I swapped them out 1 by 1 with no difference.
Any help will be appreciated.
Schematic
Eric
The Villages, FL
(This post was last modified: 10-03-2015, 05:04 PM by
Eric Adams.
Edit Reason: spelling
Threads: 562
Eric
Hum can be anything.
Does it change with tuning or stays constant?
Now, often it is a result of bad ground. Look at rivets holding ground leaves where wire solder to. These are often the culprits.
Threads: 113
City: The Villages
It stays constant, but it doesn't drown out a station when I tune it in. It kind of stays in the background.
One more thing I forgot to mention. When I first got it completed, there was no hum. I aligned both AM and FM without a sound. I put it in the cabinet and played it for about 15 or 20 minutes and then it started. Does that help?
Eric
The Villages, FL
Threads: 268
Hey Eric,
I'd try swapping the tubes you may have gotten a cathode to control grid short internally in the tube. Higher voltage heater tubes are a little more suspect than others. As Mike said check grounds is good too.
Threads: 113
City: The Villages
Thanks, Terry. Tube swap has been tried. I'm just going to check all the grounds and recheck all of my solder joints.
I'll let you guys know how it turns out.
Eric
The Villages, FL
Threads: 113
City: The Villages
Well, I took it off of the punishment shelf for another look. I tried tube swaps again. It was the 19C8! I replaced it and the hum was completely gone.
Thanks for your help everyone.
Eric
The Villages, FL
City: Sedona, AZ/Placentia/CA
Congrats Eric, one more off the punishment shelf.
Jerry
Threads: 271
City: Wilsonville
State, Province, Country: OR
