Model 46-1209
Hello - I'm wondering if anyone has any comment on a Model 46-1209. I haven't looked at it yet but have a photo and a $45 asking price. I believe it has a phonograph in the front panel. Is the phonograph typically difficult to work on or get parts for? Any comment is welcome. Thanks.
Rod Basham
Hi Rod,
The typical issue is finding a replacement cartridge and perhaps the drive puck (rubber wheel). I would anticipate it may run $30 each. Also it probably only plays 78rpm records. A lot of older consoles in the 50's got the original turntable exchange for the newer 3sp tables. Don't know if the 78 player is a must but will add a bit of cost to the price tag.
ps. After consulting the diagram I noticed that it uses a mag cartridge. i think this is the model that uses a very hard to find styles.
(11-04-2015, 10:54 PM)Radioroslyn Wrote:  Hi Rod,
Yeah that would be a D-10A changer.  That is the version with the magnetic cartridge.  I think you're right about styli being hard to come by.
Well, I'll take a look at it and maybe I can locate replacement parts. Got a few radios on my platter right now anyway. Thanks for your input, folks.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1575 online users. [Complete List]
» 1 Member(s) | 1574 Guest(s)
