41-608 changer
This may not be in the correct forum, but I'm just tackling the changer for a 41-608, and have read that all the adjustments are in the 1941 RMS book. Is this book available? Thanks,
Pat
hi pat
you can try ebay for book or ask chuck to buy a great schematic
or go to his site
http://www.philcorepairbench.com/phono.htm
sam
There are currently 5863 online users. [Complete List]
» 1 Member(s) | 5862 Guest(s)
