Cap block 6287-DU used in 116B chassis question
The schematic list this as a .3/mfd block. I know it's really two .15/mfd. Now, it also list a 200/ohm wire resistor as part of the block. I didn't see anything inside it. This block had over-heated at one point, and all the tar was melted out. I'm also a little confused to which block lugs are used for the caps, vs the resistor. Can someone clear this up for me. Here's the parts listing.
http://www.philcorepairbench.com/bblokcap.htm
-Brian
If you collect or are interested in antique telephones, please visit Classic Rotary Phones
http://www.classicrotaryphones.com/forum/index.php
My 650B used the same part. The bakelite block in mine looked identical to the universal type 6287-ODU. It uses two .15uf caps, one between terminals 1 and 2 and the other between terminals 1 and 3. IIRC, there was even a jumper on the outside between terminals 2 and 3.
Ed
For clarity sake, I'll number the lugs 1 2 & 3 from left to right, starting at the hold down bolt end. So, on mine there is also a jumper between 2 & 3. Just wondering if a resistor internally figures into any of this. I seem to remember talk of a resistor in one thread some time back.
-Brian
There was no resistor in mine. And yes, you have the numbering correct. The jumper is correct between terminals 2 and 3 on the outside. Icon_smile
Ed
Brian
I think you are confusing part 6287-D with 6287-DU in the listings on Chuck's site.
The two are different parts. 6287-D is not used in the 116B as it an older type, not the "universal" type with six lugs which was adopted at the beginning of the 1936 model year.
6287-DU, listed as 6287-ODU on Chuck's site (same specs, just different wax used to seal it), does indeed contain two 0.15 uF caps, connected externally in parallel to make 0.3 uF.
(Edit: Also, the 6287-DU/ODU does not contain a resistor.)
Ed has given you the correct info, also. Icon_smile
Yes, thank you gents. That's what I did. The listing confused me.
-Brian
Yeah Mike I figured him to be late 70s. Looked like he lived alone as thete was only seating for one person in the room ...462ron — 04:14 PM
What should I offer?
I think you have a chance at purchasing a 48-1286, based on the cabinet hardware. Only 8700 were produced, so it is a r...GarySP — 02:28 PM
I am not sure what radio it is, but seems like a 1950 AM/FM set. Or from 1948, possibly one similar to 48-1264. In any ...morzh — 12:44 PM
I have an opportunity to acquire this radio-phono, but the owner wants me to make an offer. Tried searching images, but...nocusr — 12:29 PM
So, I unwound the coil; it is 700 turns of AWG40 wire. I modeled it on a couple of different calculators and I got about...morzh — 12:29 PM
Ron From the conversation, it was my impression he was a pretty old dude who is looking to place his radios in good h...morzh — 12:16 PM
Philco 49-1040
Yes, and it's surprisingly common for early TVs to be mostly or all original. My thinking is that they were retired ear...Bob Andersen — 11:59 AM
91H Code 126 Restore
Hi Nick, Usually the dashed lines connected to components means the part is a substitute in the circuit for specific ...RodB — 09:42 AM
Mike when I got to the guy’s house to pick up the set, he gave me a tour of his home and garage. Wow, his living room co...462ron — 09:10 AM
There are currently 3792 online users. [Complete List]
» 1 Member(s) | 3791 Guest(s)
