Philco 680
#31
Bad idea for the top section as it will trap in a lot of heat. The bottom section may change some of the acoustical characteristic of the cabinet. You are better off to leave it original it being a fairly rare set.
Even though some big radios had the back, I would question the need for it.
#33
You are probally right will leave it original with no back. Thanks. Norman
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4527 online users. [Complete List]
» 1 Member(s) | 4526 Guest(s)
