41-42 philco radio escutcheon
Just tried to order a 41-290 and 42-380 philco escutcheon and found out  larry bordanaro has passed away.so sorry to hear that----good man and a great loss----does anyone know if someone else is going to  buy his equipment and produce these.I called the number on the  web site and was refered to radio daze but don't see them  in their web site catalog. hope someone can keep reproducing these----thanks
I should have them in a week.
Ed
Ed Schutz
RenovatedRadios
There are currently 9675 online users. [Complete List]
» 1 Member(s) | 9674 Guest(s)
