37-38-116 and 116X clarifiers
All these models have clarifiers and need too be repaired, here is a picture of the repair by Don Ferguson as suggested by another member who's name I can't remember. Don changed the method a little but it's easy and it works. Use 7/64 metal or plastic screws and nuts. [Image: http://i1281.photobucket.com/albums/a508...c24697.jpg] he used the rubber bracelets you can get almost any where, see if you can find brown or black to match the original color. These clarifiers are in the radio we just completed this past Monday .[Image: http://i1281.photobucket.com/albums/a508...cfa19b.jpg]
Off-topic, but considering the chevron reproduction cloth is available, why not use it?
He chose this cloth because it came in a 24 x 24 size and he liked how it looked. This radio is in his personal collection. You need two pieces of the 24 x 18 cloth everyone sells to do it as designed.
Nice looking radio and they are great performers.
Jerry
Ronin,
I bought one piece off of Kenny and he threw in the two pieces for clarifiers for free.
Philco 630csx power cord
Let's try to sort it out. So we are working with the same info here's the schematic I have: ...and here's the pin o...klondike98 — 09:03 PM
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.  I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol: As for the values, they are dependent on the 1 or 2-speaker system. The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
There are currently 2785 online users. [Complete List]
» 1 Member(s) | 2784 Guest(s)
