  • 1 Vote(s) - 2 Average
Ron or anybody
What are the specs of the output trans of 41-610 using p-p 41'S  Icon_biggrinl
Joe
RCA sez 12k plate load. Philco sez spkr is lower than a average bear like 2 ohms.
Primary: 12,000 ohms
Secondary: 5 ohms
10 watts
A Hammond 125D would work. You would want to use output taps 2 & 4 or 3 & 5 and see which combination sounds best.
Thanks guys for the reply. I think I may have one close, I will try it and see.
Thanks    Icon_thumbup
Joe
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4858 online users. [Complete List]
» 3 Member(s) | 4855 Guest(s)
