Seeking Woodworking Advice
If you next step is to reveneer the entire top anyway, I'd give the bleach a try. Even if it just turns into a learning experience you still gain something. Good Luck!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
