Another Model ID Request
What model is this?
I believe that's a 42-327T:
http://www.philcoradio.com/gallery/1942a.htm#l
Wow, 2 minutes,  that has got to be a record time for a reply. Thanks.
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4795 online users. [Complete List]
» 2 Member(s) | 4793 Guest(s)
