model 16 code 125
#46
Greg
To exhonerate or convict the vol ctl, just use another speaker. You could simply unsolder the VC leaving the FC soldered in and connect a PM speaker to the output.
Will tell you right there.
Users browsing this thread: 15 Guest(s)
Restoring Philco 96
There are currently 7604 online users. [Complete List]
» 3 Member(s) | 7601 Guest(s)
