Threads: 18
City: Ann Arbor, Michigan
I will be tackling this magnificent Philco soon. I acquired it at an estate sale a while back. It is a true barn find.
There are no Model markings that I can see. I know it will be easy to identify for the experts on the Philco Phorum.
What model is it?
Thanks!
Mark K8KZ
(This post was last modified: 10-14-2016, 03:38 PM by markmokris.)
Threads: 18
Well now that I look at it...80 rectifier, 42 push pull output....probably a 116B?
Mark
Threads: 415
City: Boston
Is that button on the upper left some kind of add on?
Good luck with it.
Threads: 564
Looks like 116.
Threads: 18
(10-14-2016, 04:07 PM)Paul Philco322 Wrote: Is that button on the upper left some kind of add on?
Good luck with it.
Yeah it definitely is Paul. It is a little rotary switch connected to nothing. I am going to try a save the cabinet. I don't think it is a candidate for a refinish. So I'll probably leave the switch in place.
Mark K8KZ
Threads: 91
City: Jonesboro
State, Province, Country: AR
Nice. Not sure I want to see the under-chassis! I can imagine it's pretty crowded!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Threads: 18
(10-14-2016, 06:23 PM)PhilcoPhan1936 Wrote: Nice. Not sure I want to see the under-chassis! I can imagine it's pretty crowded!
Not sure if I remember. Did you restore a 116 Jeff?
I snap some pictures when I get it apart. Probably will be a while though.
Mark
Threads: 91
City: Jonesboro
(10-14-2016, 10:57 PM)markmokris Wrote: (10-14-2016, 06:23 PM)PhilcoPhan1936 Wrote: Nice. Not sure I want to see the under-chassis! I can imagine it's pretty crowded!
Mark
Nope, I have never laid eyes on one, unfortunately. I can imagine being a 11 tube model that there's a lot going on under that chassis though!
Blessings,
Jeff W.
Jonesboro, Arkansas
(10-14-2016, 04:01 PM)markmokris Wrote: Well now that I look at it...80 rectifier, 42 push pull output....probably a 116B?
Bingo.
Threads: 54
(10-14-2016, 05:30 PM)markmokris Wrote: (10-14-2016, 04:07 PM)Paul Philco322 Wrote: Is that button on the upper left some kind of add on?
Good luck with it.
Mark K8KZ
There isn't realy any original finish to save, the dark walnut shaded lacquer on the top and sides is gone, and the lacquer on the front panel is sun baked on top of having that useless switch, you might as well strip it and start again.
New member
Hello jeff,
Welcome aboard !
Sincerely Riochardradiorich — 06:53 PM |
New member
Good picture,
When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM |
New member
Love the pic! I'm southern IL, so wouldn't be much help and Bob Anderson is very good on those, but lives in Chicago are...TV MAN — 05:25 PM |
:thumbup:klondike98 — 04:56 PM |
With these values I think you are OK; the Cmax for this tube is 40uF.
Your Vbb could rise a bit, but probably not too mu...morzh — 04:53 PM |
BTW, someone had replaced the original 20uF/20uF filter cap with a 47uF/33uF cap. Do you think these values are safe on ...bluecap — 04:33 PM |
You're correct. I was misinterpreting the key position. I now know where it is, and things are making sense. I appreciat...bluecap — 04:29 PM |
I think Morzh has a good thought. Check the key position. The under chassis diagram in the Philco info shows an “H” for ...klondike98 — 04:25 PM |
Philco 630csx power cord
Yes, the third wire goes to the stud on the side and is separate from the other two.
I've usually used cloth covered ...Tynwald — 03:09 PM |
New member
Have you tried Alabama Historical Radio Society?
They possibly could recommend someone.
I remember a name of Dee Hanes...morzh — 03:08 PM |
There are currently 4837 online users. [Complete List] » 2 Member(s) | 4835 Guest(s)
