VICTORY! 41-290
Thanks to all who helped me with this. The 41-290 works! In fact, it is quite a remarkable player with a whole lot of audio power that the speaker can't take. Great sensitivity and selectivity. I am a amazed how well these old radios play. Makes me think I should go back and recap everything in my 41-280. I sent it to a guy to just get it working and he did. He didn't repcap the whole thing though and kept the ones that were ok just to get it to play. If I go back into it and replace all the old cpaps and elec caps, do you think it will play better?
Again, thanks for everyone's assistance.
SF/MG
Congratulations on a job well done! Icon_smile
Regarding your 41-280 - It will definitely benefit from having all of its paper and electrolytic capacitors replaced, as well as any off-tolerance resistors. Your 41-280 will thank you for it; yes, it will certainly play better and keep playing well longer. In fact it should work just as well as your 41-290 now does, as the two chassis are nearly identical (the 290 has two extra tubes, but the circuitry is nearly the same).
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8746 online users. [Complete List]
» 3 Member(s) | 8743 Guest(s)
