Philco 38-5 veneer issues, what is this wood?
I have done several threads on veneer replacement, one not to long ago on a Philco 650PX. It will show a lot of what you ask, also done a thread on a 1936 Wurlitzer juke box veneer on whole cabinet with rounded sides. Ron could find them in archives and tag them that you can open thread.
Fred, I have a better idea:
You find them and post links.
Icon_smile
You can do a search for your own posts, or search by username "Frederick W. Taylor".
http://philcoradio.com/phorum/search.php
 It's plain cut French walnut I believe. But since some of the veneer is damaged and is scrap anyhow you could use it for gluing experiments.
Eico 232 VTVM Schematic
There are currently 10105 online users. [Complete List]
» 1 Member(s) | 10104 Guest(s)
