Did Philco ever make a 42-1008p without the BOL? I just found one on craigslist, but the pics show a changer without the BOL, and it looks original.
Pat
It isn't. Lots of BOL changers were replaced with newer, more conventional changers of various makes over the decades.
(11-10-2016, 10:13 AM)Ron Ramirez Wrote:  It isn't. Lots of BOL changers were replaced with newer, more conventional changers of various makes over the decades.
That's what I thought, Ron. I knew you'd have the answer. Think I'll get it anyway since it's the model I grew up with, and then just find a BOL changer somewhere.
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
