Philco 16B restoration
 With the weather cooperating I decided to get this one finished. Its been sitting in the basement for 2 years.
The damage was there when I got it.
[Image: http://i1336.photobucket.com/albums/o654...rnpbcq.jpg]
[Image: http://i1336.photobucket.com/albums/o654...rc79r9.jpg]
 After stripping.
[Image: http://i1336.photobucket.com/albums/o654...fv0yer.jpg]
 This is after some toner and 3 coats lacquer. It was darker than the picture but still not right.
[Image: http://i1336.photobucket.com/albums/o654...r5u3pk.jpg]
 I had to order more extra dark walnut I had ran out. Little better now.
[Image: http://i1336.photobucket.com/albums/o654...32y9hb.jpg]
  After decal and 4 more coats lacquer. Don't know if I should just wait a few weeks and rub it out and polish or sand it again and apply more lacquer. Looks pretty good as is.
[Image: http://i1336.photobucket.com/albums/o654...4dknnq.jpg]
  I still have to paint the stripes on the front.
[Image: http://i1336.photobucket.com/albums/o654...6ealcy.jpg]
Very nice! Icon_thumbup
Just went through the same process in September on my model 16:
  Very good looking Greg. Icon_thumbup  These big cabinets are a lot of work , but I do enjoy it.  If I may ask ... what did you use to paint the ivory colored stripes with?
Thanks Mike. I actually used Testors gloss white and a microbrush to paint the stripes. Carefully masking the area around the stripes off using Scotch 3M 1/4 wide plastic tape. The Testors model paint 'flows' nicely in the grooves for the stripes with the microbrush.
Thank you, I will give that a try.
Beautiful!
Both of you...
I will get to mine in the spring Icon_rolleyes
Me
WOW,,very very nice job
Very dashing!
Beautiful job!
Beautiful job on the radio indeed..Give yourself a hand!   Icon_clap Icon_clap Icon_clap
Thanks guys. Just waiting on some grill cloth and should get it completed.
Eico 232 VTVM Schematic
There are currently 9022 online users. [Complete List]
» 2 Member(s) | 9020 Guest(s)
