Philco 41-255 Wattage?
What is the wattage of the Philco 41-255 Radio at 115 volts?
Thank you.
nv3g
Oscar
On that radio, IIRC, it's about 700 to 800 ma. If you're hitting over 1 amp or more, you've got problems.
Restoring Philco 96
There are currently 7522 online users. [Complete List]
» 3 Member(s) | 7519 Guest(s)
