46-1209 phono radio issue
My phono radio button on my 46-1209 seems to be wearing out. I have to keep playing with the button to get the radio to play. No issue when pressed in for phono. Any suggestions how to fix this ? I do have a donor. Chassis.
How about trying to clean it?
(11-28-2016, 01:02 PM)morzh Wrote:  How about trying to clean it
Yes I tried that did not help much
Restoring Philco 96
There are currently 7511 online users. [Complete List]
» 3 Member(s) | 7508 Guest(s)
