Philco Bias resistor Values (B C Resistor)
Yesterday I found a complete list of these values on the Phorum but cannot find it again today. Please help.
Thank you,
This what you need?
http://www.philcorepairbench.com/bcresist.htm
Thank you Mike!  Icon_biggrin
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 9092 online users. [Complete List]
» 3 Member(s) | 9089 Guest(s)
