Speaker from model 20 into a model 70?
I am thinking of picking up a model 70 cathedral...The speaker is not original...I have a model 20 consolette that is in very rough shape and has been painted white...was wondering if the speaker out of the model 20 would fit the model 70? They look the same and may have a different output x-former but if the field coils are the same would it work?
Yes....and this link should be helpful in explaining how:
http://philcoradio.com/phorum/showthread.php?tid=14991
Thats EXACTLY what I have been trying to find!! Thanks so much!!
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 8918 online users. [Complete List]
» 3 Member(s) | 8915 Guest(s)
