Philco 46-350
OK, When trying to align I noticed this See picture...
[Image: http://i292.photobucket.com/albums/mm38/...vpbezx.jpg]
Looking at Antenna Coil It shows a 1.5 Ohm primary and a 42 Ohm Secondary.. Mine is reversed I have a 42 ohm Primary and a 1.5 Ohm Secondary. Is the schematic Wrong??? Any one else come across this? I have double checked this many times I am measuring correctly...
Plus this say this is a 265KC IF Is that right?
Skip...
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 7187 online users. [Complete List]
» 3 Member(s) | 7184 Guest(s)
