Zenith with candohm resistor
You are better off starting a new thread. Third of an amp is because the tubes filaments are third of an amp each and serialized it will be still third of an amp when hit with the sum of all voltages, the rest dissipated by the Candohm which is be third of an amp square (1/9) tines the ohms of the Cwndohm.
New member
Hello jeff, Welcome aboard ! Sincerely Riochardradiorich — 06:53 PM
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
