Threads: 242
City: West Bend, Wisconsin
I have a friend who has a nice cabinet for this model. However it's a battery powered set and he would like to find a similar 1937 Philco chassis to put in the cabinet that runs on AC. Would a 37-640B chassis fit in a 623 cabinet or which model(s) would work?
Threads: 54
Is it a complete 37-623B or just the cabinet from same? If it has the chassis and speaker with it I think I would just restore the set as is, and build a power supply for it. I'm not sure whether a 37-640B chassis would fit in the cabinet or not, the 37-640 has seven tubes and a power transformer, get someone who has one to measure it.
Threads: 242
No I think he just has the empty cabinet. He said it's in beautiful shape so I think he may be better off trying to find another 37-623B with a bad cabinet and steal the chassis and speaker from it. I suspect there is something different between the 640 and 623 size wise. He may be forced to build a power supply or get an ARBE III. I thought perhaps Ron or someone may have encountered those two models over the years for comparison sake.
oops, I thought I answered this this morning...still half asleep, I guess...
A 37-623B cabinet is the same as a 37-620B cabinet.
As for physical size of chassis, when considering AC-only chassis, the following will fit:
37-610, 37-620, 37-630, 37-640, 38-610, 38-620, 38-630
The 37-640 is indeed the same physical size as the 37-630, 37-620, etc. It does use seven tubes, but everything is crammed into a smallish chassis. I have a 37-640 chassis in my 38-624T Big Bullet cabinet, it fits just fine.
Threads: 242
Thanks Ron! I appreciate it.
Threads: 242
D'oh! Turns out he has an empty 37-623 CONSOLE cabinet, not a tombstone. I'm sure the chassis' you listed will fit, but now to figure out if he needs an 8" or 10.5" speaker to go with it?
The 37-623J (console) used an HR-12 speaker which is 10-1/2 inches. So...you know that you will need a suitable 10.5" speaker to go with whichever chassis you install.
Threads: 242
Thanks, Ron. That looked like what it needed based on your spreadsheet. Just wanted to make sure. Will see what I can find at the WARCI meet tomorrow morning.
Late last night a guy reached out in response to my posting on the Antique Radio Forum and suggested I contact Trust Aut...jrblasde — 11:01 AM |
Philco 630csx power cord
Have you opened up that plug? It may be that the third wire is connected to that brass stud on the side of the plug and ...Arran — 02:57 AM |
Model 27-84 BUZZ?Humm?
I would have to look at the schematic but it's not uncommon in 1930s AC radios to have the negative of one filter cap co...Arran — 02:46 AM |
Hello Bruce,
First all do mean a 37-84b ?
Did you take any before and after pictures ?
is it a buzz like when you touch...radiorich — 01:59 AM |
Hello Tim,
Yes, I even check all of my replacement parts when I install them and I too had a capacitor go bad not long a...radiorich — 01:54 AM |
I got back into it tonight. Problem found and resolved! Sometimes it helps to take a break and think things over. It was...TV MAN — 12:40 AM |
Thank you. I have to take a break from it for about a week. I'll have to do some thinking. I was toying with the idea ...R3Sons — 12:21 AM |
Drowning in a overloud buzz/Humm. Have already changed filter caps,bakelite blocks( caps),out of speck resistors,checked...Bruce — 12:17 AM |
Hello Mike
Here is the Link to the company the place is called Grand Brass lamp parts .
I buy all my Lamp parts plus ...radiorich — 12:00 AM |
Is the tube in your radio actually 35Z3 or 35Y4, or something else?morzh — 10:55 PM |
There are currently 2621 online users. [Complete List] » 3 Member(s) | 2618 Guest(s)
