Model 41-220 Parts list
Restoring my first Philco . Model 41-220 .I am a newbie at this but am learning one set at a time. I have a schematic . But some of the parts under the chassis are new to me. The shematic gives the part numbers but no values. Any help would be great.
73s Blaine
HI Blaine
Try this schematic. http://www.nostalgiaair.org/PagesByModel...013395.pdf It has all the values and some parts location. Looks like this chassis was used for more than one radio.
Hope tis is what you need Icon_biggrin
There are currently 11364 online users. [Complete List]
» 2 Member(s) | 11362 Guest(s)
