'36 60b Toner and Veneer
Can you please help me with the following:
1) I need to completely replace the veneer sheet that wraps the top & sides. Can you tell me what type wood veneer this is/would be best?
2) The color looks like a Medium Walnut toner would be appropriate for entire unit with maybe just a few extra coats of Medium Walnut on the base or maybe a coat of Van Dyke + Medium Walnut. Would this be correct or what would be most original?
Thanks, Joe
Note: pic is from the gallery, I just included it as a reference.
[attachment=0]
"Ignorance is bliss...'til you have to fix a radio..."
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 8250 online users. [Complete List]
» 2 Member(s) | 8248 Guest(s)
