  • 2 Vote(s) - 5 Average
Proud new owner of a 37-690
#46
Yes, it uses common Philco knobs so that was no problem Icon_smile Other than clear coating the top, I haven't touched the cabinet and don't plan to any time soon. I just don't have the room or equipment to do it right. Someday I hope to get an HVLP spray rig and space to handle a cabinet this large - or have someone else do it.
#47
(11-28-2014, 05:23 PM)Bob Andersen Wrote:  Yes, it uses common Philco knobs so that was no problem Icon_smile  Other than clear coating the top, I haven't touched the cabinet and don't plan to any time soon.  I just don't have the room or equipment to do it right.  Someday I hope to get an HVLP spray rig and space to handle a cabinet this large - or have someone else do it.
Yes the top clear finish on the 37 and 38-690's seem to have problems with peeling off. I've seen several that are missing some or most of the lacquer clear coat  Icon_sad
#48
Nice set Bob.  Look forward to one of your great video restorations on this one!
- Geoff
#49
As some of you may know I recently bought a new house and just finished moving. A lot of my collection is now in a climate controlled storage facility, but some of the best are now in a display room. That includes this 37-690.
I moved all the sets either myself or with the help of a friend. I removed some of the chassis to lighten the load which gave me the opportunity to finally take a closer look inside this beast.
Turned out the removing the lower chassis didn't help as much as we had hoped but taking out the big speaker too sure did.
[Image: https://c1.staticflickr.com/1/741/325049...3b54_c.jpg]
[Image: https://c1.staticflickr.com/4/3827/32504...b6c1_c.jpg]
[Image: https://c1.staticflickr.com/3/2902/32504...74fa_c.jpg]
While disconnecting the tweeters I noted that they both were nuts and showed evidence of having been removed. Also the cable for the one in the upper right butts up next to a tube shield.
Well that got me thinking and I did a little web searching and discovered ever example I could find showed the tweeters with the connections up top - not at the bottom. That leads me to the conclusion that mine are in upside-down!
[Image: https://c1.staticflickr.com/8/7236/69327...403a_c.jpg]
Here's one I found online.
[Image: http://www.tuberadioland.com/images/phil...ear_9_.jpg]
#50
Now here's a look at that lower chassis.
[Image: https://c1.staticflickr.com/3/2945/32533...ca08_c.jpg]
It appears some of the electrolytics were replaced way back in the day. Otherwise, I think it's all original.
[Image: https://c1.staticflickr.com/3/2825/32533...705a_c.jpg]
[Image: https://c1.staticflickr.com/1/680/325049...45d4_c.jpg]
#51
Beautiful!!! your one lucky guy good luck with it!  Icon_thumbup Icon_thumbup Icon_thumbup
#52
Those Sprague electrolytic capacitors would still be "period correct"; if it were mine, I would restuff them.
Tim KA3JRT
#53
Fantastic device ... Icon_thumbup It's my dream ... Icon_rolleyes
Users browsing this thread: 16 Guest(s)
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 2603 online users. [Complete List]
» 3 Member(s) | 2600 Guest(s)
