M-22 Phonograph
I am working on...no, getting my butt kicked by, an M-22. I have the Sams Photofact, but some views are not as clear as i would like them to be. i have several questions, but i will start here. Spring popped of the Man/Auto/Rej arm and i cannot figure out how it goes back on. Sam's photo fact is no help. pictures provided here.
Welcome to the Phorum!
Icon_wave
Sorry, can't answer your questions but hopefully someone here has the answer.
This is how they go.
Icon_thumbup Icon_thumbup
The speaker table error?
Philco 70 antenna lead
