1941 Wards Airline Model 14WG-518 on YouTube
Hello All
I have a new video posted on Youtube on a 1941 Airline.
link below if anyone interested
https://www.youtube.com/watch?v=ExDMty5X...e=youtu.be
Very good. After painting that's a very nice looking radio Icon_thumbup.
I feel your pain regarding the rubber insulated wire. I'm working on a 6-tube Zenith 6D539 with almost all rubber insulated wire and it's all disintegrating.
You're right, you can't just fix them one at a time. You end up disconnecting several more wires before you replace the one you started out to replace.
Greg O.
Whitehall, PA
