1935 model 18 trim color
I am about to restore a model 18 scalloped cathedral cabinet that has lost most of its original finish, in the pictures I have seen of the 18, 118, 144 the two lines/grooves under the bottom row of knobs look to be reflective in the photo. Does anyone know what color was used in these two trim lines?
Thanks, Todd
Light Tan.
(05-01-2012, 02:30 PM)TA Forbes Wrote:  Light Tan.
Thanks
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
There are currently 1516 online users. [Complete List]
» 2 Member(s) | 1514 Guest(s)
