Almost done with 650 H
I'm new to the phorum. Just wanted to say thanks for all the help and answers I was able to
Get from reading all the experiences you all have shared and discussed. Thanks Ron for your
Detailed description on the tuning drive assembly. I really had a time with that D ring wire. This
Is my first restoration really had fun.
Thanks again Paul
Welcome aboard, Paul! But don't thank me on the dial drive info, thank Richard Hines who supplied the text and photos. I just posted it all on his behalf. Icon_smile
For those curious, the thread in question may be found here.
Welcome to the Phorum!
Icon_wave
A photo of my 650 H
Welcome Paul!
Hi Paul and Welcome,
I've got it's big brother.
[Image: http://philcoradio.com/phorum/attachment.php?aid=11710]
Your 650H is nice looking!!!!
(03-21-2017, 10:56 PM)Radioroslyn Wrote:  Hi Paul and Welcome,
  Thanks Terry, that's a very nice 660 L (right?) its only the 2nd one I've ever seen.
And thanks for the welcome, Paul
Yup 660L. I've only seen one other too, on the net and I think it's over on the left coast.
Nice 650H! I'd really like to find one of those someday! I really like the lyre design! I have a set of lyre back chairs this Radio would look good with in the same room someday!
If they're rare, though, if I was ambitious enough, I might try to make my own cabinet. Icon_crazy
I do have a 650X unrestored that looks pretty decent. It's an 8-tube if I recall, so it should be pretty decent sounding and a good performer!
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
Here's me 650 MX, that I've had for about 30 years.  Found it in the local paper back then for $50 and restored it, as the finish was too far gone to save.  That is the original speaker cloth! Lucky for me, as reproductions back then, weren't readily available. Seems to be a fairly uncommon model. Love that trap door dial on the 650 series!
[Image: http://www.surfacezero.com/g503/data/500...0_MX_a.JPG]
[Image: http://www.surfacezero.com/g503/data/500...650_MX.JPG]
Very Nice!!!
I was hoping to get busy on refinishing my 660L but the weather this spring/summer/fall was not very conducive to spraying lacquer. Spring is coming!!
There are currently 3596 online users. [Complete List]
» 2 Member(s) | 3594 Guest(s)
