Way to Save $$ on Mohawk Toner Lacquer
I use a ton of Mohawk and, depending on where you are, found a much less expensive source than buying online.
If you go to Mohawk's site and check the "Find a Distributor" link, you can search for a distributor that's local to you. I'm in Atlanta and found a few. Turns out they sell the toner lacquer for a couple bucks less per can than online, with a greater selection and no shipping costs.
Here's the link: http://www.mohawk-finishing.com/dist_lookup.asp
If you don't find one in their list, call a local paint distributor/wholesaler and see if they carry. (not a retail paint store).
Hope that helps,
Joe
P.S. I'm not associated with Mohawk in any way, I have just found their product to be superior to work with for hand-rubbed cabinet finishes.
"Ignorance is bliss...'til you have to fix a radio..."
Thank you for sharing this information, Joe.
