Dial String on 118X
Hope this is the correct forum for this since it's not actually electronic in nature.
Wondering if anyone has the dial string diagram for the 118X chassis.  I have not really gotten into that part of it yet, so it may be very simple, but thought I'd ask ahead of time.
Thanks
Brian
Hi,
You'll find it in the Phorum Tech Section.
http://philcoradio.com/phorum/showthread.php?tid=14971
Thanks Ron!!  What I needed!
Brian
91H Code 126 Restore
