Model 95 8300 ohm resistor wattage
Does anyone know what the wattage rating is on  large 8300 ohm resistor (#40 on schematics)? I'm guessing 5 or 10 watts.
Brett
Welcome to the Phorum!
Icon_wave
Here's a link to Ron's annotated schematic for the early version of the 95 for those who may be able to answer Brett's questions: LINK
Hi Brett and welcome,
Actual dissipation is 7.5W but I generally double or triple that number.
It was probably 20-25 Watts originally, maybe the parts list will say what it was?
I just did a quick calculation as this resistor is in parallel w/the hv. 8300 ohms/250v= 7.5w. But I usually X2 or 3 so the resistor isn't flaming hot.
91H Code 126 Restore
There are currently 2791 online users. [Complete List]
» 2 Member(s) | 2789 Guest(s)
