Early 20 at our local swap meet
Ok so what is so special about it?
3 people were going on about the difference from the later 20 console.
It ended up selling for around $200.00.
Nice! Makes me want to tackle my 95 Lowboy! Icon_thumbup
Blessings,
Jeff W.
Jonesboro, Arkansas
http://jeffsradios.weebly.com
This is as much a 20 as I am Frank Sinatra.
Isn't that the 87 from Quakertown we saw here another day?
^ What Mike said. That isn't a 20, it's an 87.
Weird.....
I swear he said it was an early 20.....
He said something about the extra transformers?
Too leggy for me either way Icon_lol
Icon_smile
This type chassis with its very characteristic look was used in those radios that came before 20, including their first superhet, the 111/112.
The 20 had smaller chassis that was the first Baby-grand and would fit in a cathedral tabletop. The previous one would not; the only tabletop it would fit into was a 511.
Let alone the fact that the dial in all of these was the rotating cylinder with the surface facing the operator and so the numbers moved up-down, while in the 20 it was a circular sector type and the numbers moved left-right.
Another tell-tell sign also is the tube shield.
And, of course, the face with the knobs widely spaced in the 85 and such, vs the small triangle in the 20.
If someone paid $200 for that model 87 they obviously didn't get out much, they should have gone for a highboy cabinet version at least.
91H Code 126 Restore
Philco 70 antenna lead
There are currently 4994 online users. [Complete List]
» 2 Member(s) | 4992 Guest(s)
