  • 1 Vote(s) - 5 Average
Philco 444
And it passed careful inspection
[attachment=17711][attachment=17711]Now on the other side of the Chanel here is the 1933 equivilant also the People's Radio AKA Volksempfanger and this is a VE301Wn
Please, let's be careful with the political talk; let's not cross any lines, OK?
http://www.philcoradio.com/phorum/showth...p?tid=4586
There are currently 9385 online users. [Complete List]
» 1 Member(s) | 9384 Guest(s)
