Filament Resistor replacement
Half of a 33-3408-3 filament resistor is bad and I'm looking to replace the whole component. It is a 40/80 ohm. what wattage value would be appropriate?
TIA
elfiself
Actual dissipation is abt 3W BUT if you don't want a flaming hot resistor go w/abt X3= 7-10W.
For power resistors I triple the ating, so for 3W it is 10W for me.
Thanks Terry. The math works out to 2.4W X3 Looks like 10W should cover it.
Larry
91H Code 126 Restore
