True Blue (Arcturus)?
https://www.russoldradios.com/blog/true-blue
Arcturus seemed to have a time figuring out what to label their tubes with number and suffixes changing frequently, but this one is just wrong - -
There are currently 10035 online users. [Complete List]
» 2 Member(s) | 10033 Guest(s)
