Connecting an iPod to a 41-295
Hello,
I'm new to this GREAT site and was wondering if anyone could help me ...
I have a Philco Model 41-295 and wanted to know more about the "television" selection as on of the bush-button options. I would take this to mean that it's like a modern-day "Aux Input" that I could connect an iPod (or equivalent) to rather than a TV. And, if that's the case, can anyone tell me where to connect it? If that's what it is, I could take the chassis out and trace it with the schematic but could anyone perhaps just tell me where to connect it? Thanks (in advance)!!!
I think that the television input was actually wireless on these sets, they didn't use an input jack and a cable. Philco had a series of so called wireless record player accessories at that time that had what would later be called a phonograph oscillator, it would transmit at low power somewhere on the AM broadcast band. The pushbuttons on these 1939-42 Philcos operated a bank of tubed circuits each tuned to the radio station of preference, my guess is that the "Television" button was tuned to whatever AM broadcast frequency the planned, but never marketed, television receiver accessory was supposed to send the sound over.
The good news is that you can buy a modern equivalent of one of these wireless record player or phonograph oscillators in kit form and transmit the contents of your MP3 player, tape deck, CD player, and pick it up on the radio without adding a jack, altering an circuitry, or drilling extra holes. There are several of these on the market but there are other people on here who would be better able to recommend which unit is best.
Resurrectiion in progress.....
Which of these units he mentions is best for this purpose?
There are currently 10436 online users. [Complete List]
» 2 Member(s) | 10434 Guest(s)
