46-200 Restoration -- Mixed Results -- Help Please
Threads: 5
City: Springfield
State, Province, Country: Missouri
I just attempted my first radio restoration -- Philco Transitone 46-200. Replaced capacitors and resistors. Aligned by ear... if that is even a thing. I don't have a signal generator, etc.
I am pleased to report there was no smoke when I powered it up, and it works. So that's a plus.  )
However, I do have a few concerns and questions. Turning to the experts for help.
1) Is it normal to have a very low/faint volume (I can hear the station tuned) even when the volume is all the way down? In other words, it doesn't completely mute. Not a big deal. More of a curiosity.
2) Why would I have a low hum when the volume is all the way down? The hum is low enough that as the volume is turned up, it "drowns out" the hum. I would like to eliminate the hum.
3) Here's the biggest deal... I have a problem with the tuning capacitor (I think). It tunes well and picks up stations until I get down to about 650. Then a scratchiness starts as I continue to turn the tuning knob down to 550. The scratchiness sounds like something is touching electrically that shouldn't, and it always starts at exactly the same spot on the dial. And, a very strong local station (560) won't pick up at all... the tuner is deaf between 550-650, except for the scratchiness while I'm actually turning the knob. The tuning capacitor looks clean. I used air and a no-residue electrical cleaner.
Thank you in advance.
Bob
Threads: 268
1 could be a bad volume control but I'm betting on leakage between the diode and triode section of the det/1st audio tube. Would ignore it.
2 Lots of causes or it could just be inherent in the set.
3 Seem like you've got a bent plate on the tuning cap. Check the outside plates to see if they are rubbing on the plate next to it. If it is just bend it out a little.
(This post was last modified: 12-11-2019, 04:02 PM by Radioroslyn.)
Threads: 114
City: Sneedville, TN
With the set turned OFF, attack an ohm meter across the tuning cap. Turn it through its full rotation, and note if the meter shows any change of resistance. Do this for each section. It sounds to me like one of the plates may be shorting to an adjacent one. In that case, some very slow and careful persuasion will be needed to bend it back to where it no longer shorts. There WILL be a resistance because the cap sections are connected across coils. If you want the clearest readings, unsolder the wire from the stator section before you measure it, but that is not really necessary. A short will show up either way. Often, careful observation is all that is needed to find it, not even an electrical check.
Threads: 5
City: Springfield
Thanks, guys... I was suspecting a bent plate too. But wouldn't have thought of using an ohmmeter to check the tuning capacitor. Learning so MUCH.
Thanks again. Will update.
Threads: 50
City: Shenandoah,
One trick that I have used successfully to find where a plate might be touching or shorting out will require you to disconnect any wires connected to the tuning gang. Charge up an electrolytic and connect it to the frame and the other lead to the stator. Then in a darkened room, rotate the tuner and if there is a short or some debris between the plates, there will be a spark, helping you to locate where exactly the problem is. Also, using this method, I've had the discharge of the electrolytic actually clear the problem, sometimes! YMMV
Ron
Bendix 0626. RCA 8BX5. RCA T64
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
Threads: 5
City: Springfield
You guys are so good.
One outside plate on the tuning condenser was bent and touching.
I couldn't see it without completely removing the tuning condenser from the chassis, but once I did it was easy to spot and fix.
Thank you so much for your help. Radio now plays great, and tunes well throughout the entire AM band.
Bob
(This post was last modified: 12-13-2019, 04:10 PM by rps65619.)
Mike,
Lookup murrayatuptown on ARF. Seems he has a dilemma with surplus field coils. Could get lucky and have what y...Chas — 01:26 PM |
Hello Mike,
I have not checked to see if my console has a fuse or not and far as sets go I have early 30s General Motor...radiorich — 11:25 AM |
Ron
I forgot, but when you said "phone number", I remembered, caus I usually remember how I act when I need...morzh — 11:12 AM |
You have an extensive collection of Philcos, Mike! I’m always excited to see each new one. Agreed on the power supply fu...jrblasde — 10:50 AM |
Hi Mike, that 84 sure looks great. You don’t often see these antique radios with a fuse like yours has. I usually instal...462ron — 10:22 AM |
Hello Mike,
Wow ! far as my AK it does work and the cabinet is in nice shape so is my chassis anyway here is a photo of...radiorich — 02:59 AM |
Nice radio, Mike! Here's hoping it was well rebuilt. Take care and BE HEALTHY! GaryGarySP — 12:12 AM |
Rich
yes, this is the way I got it. I have just put it on the table and took it apart.
I suspect it even might work,...morzh — 11:31 PM |
Hello mike,
What nice looking radio I have one AK in my collection it's a console I have not started restoring it yet ....radiorich — 11:21 PM |
91H Code 126 Restore
Just to make it more confusing here is another model 91 schematic that doesn't show parts with dotted lines in that spot...Arran — 10:37 PM |
There are currently 4356 online users. [Complete List] » 1 Member(s) | 4355 Guest(s)
