Threads: 20
City: Portland, OR
Finished my first radio. Its a 370 Chairside that I picked up for $35 earlier in the year. Went through the chassis replaced all the paper caps and electrolytics along with one mica and all but one resistor. Couldn't figure out why I couldn't get any stations until I discovered that a previous repair at some point in it's life rendered it inoperable. Cathode of the oscillator was not wired back to the B.C. Resistor.
Threads: 268
Very nice !!! I wish either one of mine looked that good!!
Threads: 27
City: Petaluma, CA
That looks very nice and it's right at home next to the rockin' chair. How well does it perform?
Craig R.
(This post was last modified: 12-31-2013, 12:43 AM by
VntgRads.)
Threads: 271
City: Wilsonville
State, Province, Country: OR
Threads: 2
City: Renton, Wa
Threads: 92
City: Clayton, NC
Threads: 10
City: Warren, Ohio
Threads: 7
City: Osceola, IN
Beautiful radio, and awesome job on the restoration!
Threads: 20
City: Portland, OR
Thanks for the comments. The radio performs very well. I am building an AM transmitter (Antique Radio Forms 12AV6-12CS6 Transmitter) so I can play some some decent music along with Tube Talk podcasts.
Threads: 268
I'll mention one slight thing I noticed about my working 370. The speaker is mounted close to the power transformer. This seems to cause a bit of 60cy hum pickup from the magnetic field. I moved the speaker away from the radio chassis and it clears up.
Threads: 20
City: Portland, OR
Did you try grounding the chassis?
Roy
Threads: 562
Roy
Tis is exactly the case where grounding does squat.
Extra heavy soft iron shield around the transformer would help.
Threads: 97
City: Poughkeepsie, N.Y.
Roy, very nice job on the chairside radio..Have yet to see one in person in my neck of the woods. I guess they were not very popular?
Threads: 268
They do pop up on epay from time to time. I saw one about a week or two ago. If you are in the market check out the top closely as I've seen some that have been reveneered with a solid sheet of veneer.
