If you like other sets
here's a site that has some odds and ends for European sets.
https://www.bendijkman.nl/
Usually when you are in the bathroom European Icon_lolno
Icon_smile
Thanks for posting that link!  Nice to have another go-to site for European radio parts.
Craig R.
They have an interesting selection of grille cloth that is unavailable here in the states.
Nice cloths!   Icon_surprised
I could have used that scalloped Zenith cloth about a year ago! Oh well...that radio is gone.
There are currently 9819 online users. [Complete List]
» 1 Member(s) | 9818 Guest(s)
