[split] Philco 60B Restoration
This is a great thread. I'm bringing it to the top because I have the exact same model and have questions about the cabinet. I need to replace veneer that is missing on the top of the arch and need to know the species of wood that was used so that I can purchase the correct veneer. Is it walnut or mahogany? I'm going to preserve as much of the original veneer and finish as possible. Also, the color of toner I need to match it up would be appreciated. Thanks very much!
Best regards<
Mike
[Moderator note] Split from https://philcoradio.com/phorum/showthread.php?tid=12172
Guess I'm going with walnut.
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
Var resistor id
There are currently 5820 online users. [Complete List]
» 2 Member(s) | 5818 Guest(s)
