Model R-1710
Can someone tell me some information on this model? Year?
Hi and welcome,
It would be helpful if you could post a pic or two.
Just as a rough guess it could be some sort of set from the early 70's or a 30's auto radio.
Probably a 1968 model.
See
https://philcoradio.com/library/index.ph...age-guide/
I will post pictures of later
It might be in Sam's 961-4 couldn't find anything for free.
Well, here's a head scratcher. I had been using my 1077 while working on the Emerson and the last time I tried to use it...TV MAN — 01:26 PM
Indeed. Thank you all. I'll remove and test the rest of the transistors. I'm trying to trace everything at the test p...R3Sons — 12:06 PM
Yes, if the speaker was disconnected or bad connections, it could cause high enough voltage spikes on the collector to k...462ron — 10:40 AM
42-345 Resistors
Good.morzh — 10:38 AM
I would check things around before simply replacing the transistor. Something killef it.morzh — 10:37 AM
÷1 to Sincere Richard. I use Mouser but either is the way to go. I'm sure the others, like justradios, are in the group...RodB — 10:24 AM
RS3, that output transistor X6…AR14, can be replaced with a GE-3 or ECG-121, probably others too. Ron462ron — 10:01 AM
Philco 7053
Thread moved to test equipment section. (I have not used one of these)klondike98 — 07:05 AM
Thank you Richard.R3Sons — 01:37 AM
R3Sons, I buy my resistors from either digi key or mouser ! Sincerely Richardradiorich — 01:28 AM
There are currently 3013 online users. [Complete List]
» 2 Member(s) | 3011 Guest(s)
