model 38-10 no reception after recap
Ok, thanks. Those wires (ex. where my probe is pointed in last pic) are soldered to the winding under the wax?
Probably but the wax melts quick when touched by the soldering iron.
There are currently 4650 online users. [Complete List]
» 2 Member(s) | 4648 Guest(s)
