1949 Airline Model 94HA-1528C Repair and Radio Contest on Youtube
I have a new video repairing a 1949 Airline Model 94HA-1528C .
also....You may enter my contest to win
link below if interested
https://youtu.be/dIlengP3fMw
Hey Buzz, I have been watching your videos for some time. I just became a member
here at the end of last year, great to see your in this Phorum. Drop me a line or two
when you can. Off to see your new creation. Icon_razz
Hi Buzz, didn't know you were on this forum. Great video's with a lot of humor, just what we need at this time. Thanks.
Jim
Spring Lake MI
Philco 91 Tuning Condenser
