Unboxing 2 Forgotten Radios on YouTube
Today, I open up 2 boxes containing radios unopened and forgotten about for 6 years.
Lets open them up!
If interested link below
https://youtu.be/Uf9bHYC4Dko
Neat video Icon_clap
M R Radios   C M Tubes
Thank You Sir
Nice video.
I was wondering about that variac staying hot but then I figured since you posted that video, nothing bad happened Icon_smile
One thing: I am not sure but it seems like the spray said "contact cleaner". If it is, I wouldn't use it on a pot, as at least some are known to etch the resistant off of the omega. Fader lube, like Deoxit F5 is safe and does a good job removing scratchinness from volume controls.
I forgot to turn the variac off, good thing the radio was off, haha
o man, is that all there is??? Icon_e_biggrin
Fun video Buzz, thanks   Icon_thumbup
Thanks Buzz.
I always enjoy your videos.
Greg O.
Whitehall, PA
