Looking for old thread
Am looking for a thread that discussed the plug in antenna transformer for the '41 models. There was a hand drawn diagram included. Anyone got a link?
Is this it?
https://www.philcoradio.com/phorum/showt...p?tid=2599
I have found that it is much easier to find things from the Phorum by searching on Google as follows:
Type in the question you have and follow it with site:philcoradio.com. Example:
Philco antenna switch site:philcoradio.com
This generally works much better than the Phorum's own built-in search.
Tnx Ron! Yes that's the one I was seeking. I did try to find it by using Google but didn't find it. I do try to do my homework before I post (believe it or not).
Maybe that thread it worthy of posting in the library.
I often use Google to find stuff on the Phorum.
It gives the text version and then allows to go to the source.
There are currently 3970 online users. [Complete List]
» 1 Member(s) | 3969 Guest(s)
